Can't display vector of structs with flatbuffers in datalayer browser
CodeRat
Hello, I have a problem when displaying vectors of structs in the datalayer browser, see screenshot. I get the error Incorrect type. Expected "object". (json undefined) [1:1-1:5].
auto snapDir = snapPath();
    std::filesystem::path dir = "compiled"; // Build environment: Compiled files are stored into that sub directory
    if (snapDir != nullptr)
        dir = snapDir; // Snap environment: Compiled files are stored into the $SNAP directory
    std::filesystem::path fileBfbs1 = dir / "PointClusters.bfbs";
    result = provider->registerType("types/vectorData/PointClusters", fileBfbs1);
    if (STATUS_FAILED(result))
        std::cout << "WARN Register type 'types/vectorData/PointClusters' " << fileBfbs1 << " failed with: " << result.toString() << std::endl;
    std::filesystem::path fileMddb = dir / "metadata.mddb";
    result = provider->registerType("datalayer", fileMddb);
        std::cout << "WARN Register " << fileBfbs1 << " failed with: " << result.toString() << std::endl;
    result = provider->registerNode("/flatbuffers/meinPointCluster", m_locatorProviderNode);
    flatbuffers::FlatBufferBuilder builder1;
    auto flatbuffersPointClusters1 = binaryVectors::CreatePointClusters(builder1, 43.0, 4.0, 555.0, 4, 10);
    auto flatbuffersPointClusters2 = binaryVectors::CreatePointClusters(builder1, 44.0, 4.0, 555.0, 4, 10);
    auto flatbuffersPointClusters3 = binaryVectors::CreatePointClusters(builder1, 45.0, 4.0, 555.0, 4, 10);
    std::vector<flatbuffers::Offset<binaryVectors::PointClusters>> PointClusterVector;
    PointClusterVector.push_back(flatbuffersPointClusters1);
    PointClusterVector.push_back(flatbuffersPointClusters2);
    PointClusterVector.push_back(flatbuffersPointClusters3);
    auto pointClusterFinished = builder1.CreateVector(PointClusterVector);
    std::vector<flatbuffers::Offset<binaryVectors::Pose2D>> Pose2DVector;
    builder1.Finish(pointClusterFinished);
    meinPointCluster.shareFlatbuffers(builder1);
 Is displaying vectors of structs supported in the datalayer browser web ui?
nickH
Hi @CodeRat
I made some changes to the C++ sample datalayer.register.node and tested the FlatBuffer schema you sent in your post.
I managed to provide the FlatBuffer in the Data Layer with these lines:
// Register a node as flatbuffer value
  flatbuffers::FlatBufferBuilder builder;
  std::vector<flatbuffers::Offset<vectorPointClusters::PointClusters>> vecPointClusters;
  auto actPointClusters = vectorPointClusters::CreatePointClusters(builder, 43.0, 4.0, 555.0, 4, 10);
  vecPointClusters.push_back(actPointClusters);
  auto actPointClusters2 = vectorPointClusters::CreatePointClusters(builder, 2.0, 6.0, 222.0, 6, 7);
  vecPointClusters.push_back(actPointClusters2);
  auto pointClusterVec = builder.CreateVector(vecPointClusters);
  vectorPointClusters::PointClusterVecBuilder vecClusters(builder);
  vecClusters.add_pointcluster_vec(pointClusterVec);
  auto flattbufferFinished = vecClusters.Finish();
  builder.Finish(flattbufferFinished);
  comm::datalayer::Variant myFlatbuffer;
  myFlatbuffer.shareFlatbuffers(builder);
  std::cout << "INFO Register node 'sdk-cpp-registernode/myFlatbuffer'  " << std::endl;
  result = provider->registerNode("sdk-cpp-registernode/myFlatbuffer", new MyProviderNode(myFlatbuffer));
Thats what it looks like in the Data Layer:
FlatBuffer in Data LayerFlatBuffer in Data Layer
I attached also the full project here, so you can test it yourself.
Thank you for the reply :). I have successfully implemented it in my version, howerver I was stuck for a long time figuring out why my nodes didn't have any values. It seems like the folder in /types has to have the same name as the fbs file.
