C++ datalayer.register.node example at a Virtual Control - node sometimes not available
benediktB
Occasional Visitor
i created a snap with the C++ datalayer.register.node example and deployed it at a Virtual CtrlX. The node appears at the UI of the Datalayer and is also accessible.
But sometimes the nodes disappear for 10-20s from the user interface of the automation snap. At this time, access to the node's url via other tools, such as postman, that were previously successful, are requested with a 404 error. After 10-20s the node appears and is accessible again. Is anybody facing the same issue or have a solution?
I'm using the CtrX Works Version 1.2.2.
Please also always add the version of the SDK that is used.
At the older version there are still bugs in the system and SDK. Please use the release version RM20.07.1 that will be available the next days and test again.
I've got an update on this (I work together with benediktB):
We updated everything to RM20.7.1 (ctrlX Works 1.4.1, SDK 1.4.2,....) --> all problems are gone! Thank you.
