02-27-2023 10:57 AM
I have connected to OEE.Ai by using example node-red include of in GitLab.
At the Node-red:
OEE node has already connected status.
At the OEE's Sensor:
I can view data counting from client side.
how ever, there is no data visualize in Machine/Measurements.
A few questions on this topic.
- How is data from Node-red can push into the tags on OEE? At the moment, I only see data can publish by ID & Token via "OEE.AI cloud connector" node. But, I can't use more than 1 node because of license limited even I installed license for 1 device within 1 year.
- Most of the instruction in OEE for connection are using API. So, in Node-red is there any insruction for quickly connect to cloud or we keep using API.
please share if you may know those things.
Much appreciate!
02-28-2023 07:07 AM
