10-03-2023 06:00 PM
I would like to set the parameter P-0-0300 by I/O Engineering startup parameter.
i used a syntax list as shown in the attached screenshot.
My problem is : the drive doesn't switch to OP mode when i add this line in the list of parameters.
I dont' know if the syntax is correct or not, are there any solutions to this problem?
thanks a lot,
10-04-2023 09:13 AM
Yes, very good question indeed.
I have same problem to solve... ☹️
10-04-2023 02:28 PM
Could you tell us which device you try to write this parameter to? It looks like some drive (HCS) but not an ctrlX IO. So I can move it to the correct sub forum.
P-0-0300 is a 4 Byte variable list so parameters would be e.g.
We will check this in the next days.
10-04-2023 03:43 PM
Thanks for your reply,
I would like to write this parameter into indradrive_MPE20 by startup parameters.
