03-01-2023 11:34 AM
Does the EAL library work with IAC valves with HDx-20 firmware?
The valves my customer is using are :
Their machine user interface is written in C++. They want to write some commissioning pages on their HMI.
The motion is sequenced using an Allen Bradley PLC over Ethernet/IP. However, I don't want to set the parameters required via cyclic or Acyclic comms on ethernet/IP.
03-07-2023 01:49 PM
EAL will be able to communicate with HDx20 firmware.
So it should be possible to create a visu by reading parameters.
