ctrlx X3Plus profinet
JHU1XI1
PN communication requires configuring different data types. How to configure different data types.
For example, if I need WORD and REAL now, what do I need to do.
cc2go
it's like you started, when you load the "Datatype example" as configuration you are able to see it in the manage app data.
The "Datatype example" shows "Example template to demonstrate datatypes".
With this you should be able to create your own config, which you can upload, when the Profinet Device app is in config mode and the tab "Upload configuration" is used.
JHU1XI1
I have tried configuring two data types and uploading them to the Core, but it will report an error.
cc2go
The following I tried, this was successful. Please compare to yours, if you don't find a solution, please share yours which is failing
  "name": "in_out_64word",
  "description": "64 word and real",
  "configdataVector": [
      "moduleType": "INPUTS",
      "moduleIndex": 0,
      "containerType": "TYPE_ARRAY_OF_REAL",
      "numberElements": 2
      "moduleIndex": 0,
      "containerType": "TYPE_REAL",
      "numberElements": 1
      "moduleIndex": 0,
      "containerType": "TYPE_ARRAY_OF_WORD",
      "numberElements": 64
      "moduleType": "OUTPUTS",
      "moduleIndex": 0,
      "numberElements": 2
      "moduleIndex": 0,
      "numberElements": 1
      "moduleIndex": 0,
