06-28-2023 02:37 PM
I'm working on an application that is using a Rockwell PLC communicating to a ctrlX core. I'm looking for the EDS files for the ctrlX, to load into Rockwell Studio 5000. Can you tell me where i can download the EDS files please.
Paul
06-30-2023 08:07 AM
Hi Paul,
EtherNet/IP can be supported on the ctrlX CORE by installing the PLC-integratable packages from CODESYS. EtherNet/IP Scanner or Device can be realized. Find further details here: CODESYS - Fieldbus Communication
If you download the CODESYS EtherNet/IP Adapter from the Collaboration Room. The EDS adapter file is included in the delivery scope.
For further support of the CODESYS - PLC Add-ons contact this sub-forum: CODESYS - PLC Add-ons
06-30-2023 05:01 PM
Hi Nick,
Thanks. Got it sorted.
Have added some additional infomation on how to create the EDS file and import into Logix Designer.
Paul
