01-26-2022 10:56 PM
did anybody try to use BACnet via Node-Red https://flows.nodered.org/node/node-red-contrib-bacnet in combination with the ctrlX CORE?
Thank you,
Oliver
02-02-2022 12:02 PM
Hi TK2588,
I didn't try it with other devices, but as an import is possible without any warning, it seems no native bindings are used, so should work.
