02-03-2022 08:39 AM
Hello all,
Anybody having experience in using a Powerlink to Ethercat converter, enabling a ctrlX drive on a Powerlink network ?
Do you nee a componenter or could it theoretical be done with an app-solution ?
Thank you
02-03-2022 01:39 PM
Hi Servodude,
as a ctrlX DRIVE cannot run an app, it would need a converter.
Powerlink slave to EtherCAT Master, not sure if such converter is available on the market.
An App could run on a ctrlX CORE, but this app needs to implement a Powerlink Slave and copy the values to the EtherCAT Master app and vice versa.
Such an app neither exists nor is planned from our side.
