01-25-2024 04:25 AM - last edited on 01-25-2024 07:14 AM by CodeShepherd
Hi @CodeShepherd ,
Do you know if it is possible to switch EtherCAT master status to OP using OPCUA Client?
I have tried using UA.TestClient unfortunately the datatype for the masterstate node datatype is ExtensionObject.
Is it possible to decode OPCUA client datatype ExpansionObjects value to string and write OP and INIT value to masterstate to switch between EtherCAT OP and INIT?
Warmest regards,
01-25-2024 07:26 AM - edited 01-25-2024 07:27 AM
Moved to own topic from "Switching the ethercatmaster between states".
Which version of the ctrlX OPC UA server app is used? And which version of UA.Testclient?
Setting state is working fine in server version 2.04 using e.g. UaExpert version 1.7.1 540:
01-25-2024 07:50 AM - edited 01-25-2024 08:06 AM
I am using ctrlX OPCUA Server v2.4.0 and UA.Test Client v2.4.1, the UA.Test Client does not decode the datatype ExtensionObject and cant see the OP and INIT options.
Using the UaExpert software is working now i can see the INIT and OP options.
01-25-2024 10:33 AM
We gonna check this internally. Thanks for bringing it up.
01-25-2024 04:13 PM - edited 01-25-2024 04:14 PM
Feature is included in UA.Testclient version 2.4.2 available now in the store area.
