OPC UA Incorrect Display Names
Sgilk
Contributor
I've established a connection to an OPC UA Server running on a ctrlX Core, but some of the display name values within the PLC node of the DataLayer are incorrect. These autopopulate with the correct names when I connect to a virtual core.
Could you send us a system report or at least tell us which system and OPCUA server version you are using?
This is already working well for quite a time:
UaExpert connection to PLCUaExpert connection to PLC
Here is the system report.
The nodes are named correctly when viewing the datalayer in the ctrlX Web UI. They also show as 'displayName' in the WebIQ Designer client.
We found that there is a problem with the older versions of the system and the OPCUA server 1.12.4.
Please update to the official release version 1.12.6 of the system and also the OPCUA Server 1.12.5.
