07-31-2020 11:54 AM
Will it be possible to exchange files with ctrlX CORE via SFTP without a root user?
What are the possibilities to exchange/copy files to CORE file system or will it even be possible to mount a windows drive?
08-12-2020 08:56 AM
Prefered mechanism to exchange files between HMI and Core is OPC UA. So you can i. e. read the file on HMI side and write it to a PLC Variable via OPC UA.
SFTP exchange will also work without a root user.
