09-28-2022 11:24 AM
I am trying to use custom CA certificate for ctrlX OPC UA Server Application . But they are not working.
I uploaded a certificate in the category of Own but OPC UA Server is still sending its default certificate instead of this newly uploaded one.
Please help on this
09-29-2022 06:38 AM
currently the OPC UA Server App only supports self signed certificate as described here: https://docs.automation.boschrexroth.com/doc/3485899442/certificate-management/2-04/en/.
But you can experiment with 1.16:
There you can configure the OPC UA Server certififcate configuration in opcuaserver/serverconfig/opcua_appconfig.cfg. Therefore you have to save archive of you data first on your local machine and modify it there and load and activate this on the ctrlX again. After that a restart of the OPC UA Server App oder ctrlX is required.
Please keep in mind that the server also needs a corresponding private key for the certificate.
We currently work on solution to address use-cases with CAs. If you can describe your use-case a little more we can also consider this in our future solution.
smueller
