I like to run the PackML on the ctrlX
I found this package to install on codesys 3.5
https://store.codesys.com/en/omac-packml-state-machine.html
But I still did not manage to get it running. Is there example project is available ?
I have an unofficial library I can share. It is a reworking of a library for MLC that has been in use for several years. In addition to the main PackML state handler, there is an error handling mechanism plus some addtional tools. A modular design pattern sometimes called Make2Pack is supported.
Library documentation is attached. If you are interested, please DM me your contact details.
Dear,
if you install the package from https://store.codesys.com/en/omac-packml-state-machine.html you will find the example in your directory C:\Users\<username>\CODESYS Examples\OMAC PackML State Machine\1.0.0.1
Open it with your IDE and click "Update Device". I have just tested it and it works without any restrictions.
Best regards!
