Will there be a PackML template for codesys (ctrlX) available
Pinball_NL
I like to run the PackML on the ctrlX
I found this package to install on codesys 3.5
https://store.codesys.com/en/omac-packml-state-machine.html
But I still did not manage to get it running. Is there example project is available ?
bostroemc
I have an unofficial library I can share.  It is a reworking of a library for MLC that has been in use for several years.  In addition to the main PackML state handler, there is an error handling mechanism plus some addtional tools.  A modular design pattern sometimes called Make2Pack is supported.
Library documentation is attached.  If you are interested, please DM me your contact details.
CDSAddons
Dear,
if you install the package from https://store.codesys.com/en/omac-packml-state-machine.html you will find the example in your directory C:\Users\<username>\CODESYS Examples\OMAC PackML State Machine\1.0.0.1
Open it with your IDE and click "Update Device". I have just tested it and it works without any restrictions.
Best regards!
