CXA_SoftMotion_BusTaskInterval Library missing message after enabling SoftMotion
DCEN_Tony
After enabling softmotion (4.12.0.0 package install) on a ctrlX WORKS V-0120.2 PLC project the message "Could not open library CXA_SoftMotion_BusTaskInterval 4.10.0.0 beacuase it has not been installed to the system" appears.  I tried to download from the subsequent dialogue but it failed.  Please see attached picture for more info.
Is this library necessary, if so how can I get a copy?
Many thanks
bostroemc
The library should already be installed.  In the Library Manager, select Placeholders and map the library manually:
georkueh
if this version of the library is not available set the placeholder manually to the one, that is available with your installation. Maybe there's a new/other version available.
kind regards
