CODESYS IIoT Libraries - HTTP Client - TCP_INIT_ERROR
alnapi
I have purchased CODESYS IIoT Libraries License and installed package 1.3.0.0.
I use the HttpClient function block for simply sending HTTP requests to a local server.
Now, if I want to send the data I have no problem to send the first data blocks, but after a various number of sent data I get a TCP_INIT_ERROR.
I have no explaination, why I get the TCP_INIT_ERROR.
Did anyone already had the same problem?
Do you have any idea what could be the problem?
Sgilk
Contributor
Is there any reason you cannot use the latest version? It looks like there may have been a bug fix for this issue in version 1.4.0.0.
alnapi
Thanks for your help.
I can't find the version you are showing me.
Where can I find it?
You can find this on the CODESYS store. You'll need an account to access them. I'm not sure why version 1.3.0.0 is in the Collaboration Rooms.
CODESYS IIoT Libraries SL
alnapi
Version 1.8.0.0 installed.
The problem no longer occurred.
Thanks again for the help.
