06-07-2021 04:26 PM
I came across the 3S storage library today in the library manager. What documentation is available for this library? Can it act as a database for PLC applications?
06-09-2021 12:09 PM
Please see CODESYS store for further information.
06-09-2021 02:02 PM
Thank you for the link but there is no documentation there. Is there documentatoin elsewhere?
06-10-2021 06:34 AM
It is a CODESYS library. So you have to ask this question at the CODESYS forum which you can find via CODESYS homepage ....
09-24-2021 02:42 PM
this library is used for saving trend/alarms data into a sqlite db ( and Application Composer Datalogger)
It is at the moment not recommended for application use - there are plans to add an api for it. (and sure documentation)
But see no date then this will be finished
