02-08-2023 04:12 PM
When I habe to configure more than 2000+ Endpoints I want to read in with the Device Bridge App - is there a possibilty to perform a mass configuration thru e.g. file editing + uploading?
Thanks in advanced!
02-16-2023 09:42 AM - edited 02-16-2023 09:47 AM
We will be adding the feature for Import of tags in RM.04.
Via this, Mass configuration would be possible
09-07-2023 03:44 PM
could you tell me a date. Would be very fine if you have i.e. 80 different inputs (ctrlX IO inputs coming via the datalayer).
09-07-2023 04:19 PM - edited 09-07-2023 04:19 PM
Tag Import feature has been added to the latest release. Mass import is possible
(Prerequisite - Should be a csv file)
Product Support
09-11-2023 05:22 PM - edited 09-12-2023 09:36 AM
Is it allready in the version 3.2.9.5517 (what I have) ?? Where to find the new function ?
09-20-2023 05:52 AM - edited 09-20-2023 05:52 AM
09-26-2023 04:14 PM
If we try to EXPORT then we get the following error:
Here from the browser inspect:
And when we try to IMPORT from a CSV-file as mentioned in the "Download Guidlines" we get this error:
Is this the right way ?
09-26-2023 04:59 PM - edited 09-26-2023 04:59 PM
Tag import and export have concerns as you rightly mentioned.
This will be addressed in our next release and latest snap will be shared at the earliest
Product Support
10-03-2023 11:56 AM - edited 10-03-2023 12:06 PM
The above import / export concern has been resolved
Kindly try with the new snap version and perform the mass import. Should work !!
Snap version details attached fyi.
Prerequisite -> .csv file
Note:
After import please go one level up and click on the device or tag group again to view the imported tags.
Product Support
03-22-2024 07:51 PM
The latest DeviceBridge version downloadable from the store and how-to is 3.2.9.5517 (as of March 22nd, 2024).
https://developer.community.boschrexroth.com/t5/Store-and-How-to/Bosch-DeviceBridge/ba-p/50243
When will the 3.2.9.5928 version with the import/export fix be availble?
Thanks,
04-03-2024 02:10 PM
Kindly check the version 3.2.9.5928. Import / Export feature has been enabled in this version.
Meanwhile we will also check on the availability
Product Support
2 weeks ago
I also would like to test this new feature to import/export configuration. I don't find this version 3.2.9.5928 inside the collaboration room - ctrlX store. The last available is : 3.2.9.5517.
Could I have it?
Thanks for your help
