08-06-2024 03:33 AM
App: Bosch - DeviceBridge (boschrexroth.com)
When using the "Device Bridge" app, how are tags & licenses managed? I put an example.
In other words, is it possible to:
08-30-2024 08:15 AM - edited 08-30-2024 08:16 AM
Thanks for your query...
Thanks
Product Support
3 weeks ago
Hello Support Team,
If requirement is to handle more than 2000tags then is recommened to use based of the Device or tag count. or will it be the limiation to use maximum of 2000tags / 20devices.
Does the this device or tag count is applicable for those from where the Device bridge app will collect the tag informations? or to the deliverable target also get counted here.
like below
1PLC + 100 tags => data to be delivered to SQL & MES : will the license count 1Device 100tag sufficient here? or should we also count the SQL & MES as devices?
