08-03-2023 12:48 AM
Hello Sir
I'm trying to install the app Build Environment.
I could select the function in version V-0120.4. However, I could not do it in version 0112.10.
Can not it use on the same PC if ctrlX work is a different version?
Must It delete the old version?
Best regards
KIRIKI
08-03-2023 07:25 AM
Hi Kiriki,
the App Build Environment is integrated in ctrlX WORKS since Version 1.14. It is not available in older versions.
Anyhow, you can just download the SDK 1.12 from GitHub and still use this version in an App Build Environment which was created with a newer Version (e.g. 1.20). Then you would have to download the SDK manually from GitHub and unzip it in your App Build Environment.
