03-06-2024 04:55 PM - edited 03-06-2024 04:56 PM
Hi all,
Hopefully this is the right place to post this, but I'm encountering these errors with my CtrlX Core Virtual upon starting the core.
I'm using CtrlX Works 1.20.10 and these errors are appearing on the diagnostics of a freshly created Virtual CtrlX Core. I have no apps installed on the core currently.
These are the settings for my virtual core:
Deleting and creating a new virtual core does not seem to resolve this issue. I've also tried creating a core with image version 1.20.0 and I am having the same errors.
Any idea on what might be causing this? I haven't had any problems so far with running apps, but I would rather be on the safer side and try to get these errors taken care of. The apps I tested were PLC-V-01.20.6, Node-Red, and the sample go webserver app compiled from the SDK.
Attached is my full diagnostics log from a newly created CtrlX Virtual Core with no apps.
03-08-2024 03:29 PM
Update:
I was able to resolve this issue by installing CtrlX Works version 2.4.1
