03-28-2024 01:56 PM
Customer states the configurator don't give the cable typecode during the process. I tried, with same result
CTRLX557193
where is the mistake?
03-28-2024 02:58 PM
Since IndraDrive Cs/HCS01 is a relatively new addition to the ctrlX DRIVE configurator, a few things might still be necessary to maintain.
For the desired HCS01...W0008 and MS2N with hybrid connector H the cable type is RH2-011BBB-NN-xxx,x (add length)
a month ago
Hi @adamfuchs
this seems to be a bug in ctrlX Configurator. We are trying to fix this bug as soon as possible.
Until then please use the cable described from @macmotor !
Thank you in advance!
Benedikt
