SAFEX C.15 maximum of Double Channel Outputs
Pinball_NL
In the description of the Outputs it says  6 SDO (0,5amp)  4 SDO (2amp) and 1 SDOR
What we need is 8x Double channel output. With the output count in the specifications you should say that this is possible. But when I configure it, I can not add more then 6 double channel outputs.
Is it possible to make 8 double channel output with the standart configuration ?
ChrM
Hi Michel,
the answer is YES for the SAFEX-C.15 which you mentioned in the headline !
Refer to:  ctrlX SAFETY Installation Manual (purpose: Project Planning)
Check: This works !
I have 4 Double channels and(+) 8 single ‘semiconductors’ channels which I can combine to 4 double channels.
Problem soved.
