Hello.
Is the Input Configuration:File Transfer possible feature in visualization?
I read from Codesys forums that it needs to be enabled from configuration file:
[CmpWebServerHandlerV3]
AllowFileTransferServices=1
Is this allowed/possible with Core?
currently the user is not able to modify the cfg file. We're working on a mechanism that will allow the user to access specified settings within the cfg file. So currently the setting must be set by our system firmware. We will add this requirement to the backlog.
kind regards
