04-01-2022 10:34 AM - edited 04-01-2022 10:35 AM
Dear ctrlX Community!
We would like to connect several Keyence scanner to ctrlX Core via USB RS232 adapter.
I successfully sent and received data in node-RED (with /dev/ttyUSB0 path), but we need to use this solution in PLC runtime.
I tried to open the serial port with SysCom library without any success.
Is there any possibility to handle the USB RS232 adapter in the PLC environment?
Thanks in advance!
04-01-2022 12:11 PM
I don't know if it is possible or not but i would like to know the answer too. 🤗
Mauro
04-01-2022 12:43 PM
we will have a look into the topic and come back to you.
Have a nice weekend.
04-13-2022 08:05 AM
After the V1.14 update, we tried to set the following parameters to plc_system.cfg:
[syscom]
linux.devicefile=/dev/ttyUSB0
portnum := COM.SysCom.SYS_COMPORT1;
This solution works with Codesys PLC runtime on Raspberry Pi, but no success on ctrlX.
Is there any chance to step forward in this question?
04-25-2022 08:50 AM
Hi 8run0tti,
update, it is not yet possible to use it.
We are working on it, most likely it will be available in the next version 1.16 from august on.
11-22-2022 11:24 AM
Any news here?
11-24-2022 03:17 PM
Hi 8run0tti,
we implemented the support from version 1.16 on.
Find here some example code.
PROGRAM PLC_PRG
VAR
result : Syscom.RTS_IEC_RESULT;
handle : Syscom.RTS_IEC_HANDLE;
settings : Syscom.SysComSettings;
bDone : BOOL;
arByte : ARRAY[0..99] OF BYTE;
udiReturn : UDINT;
iState : INT := 0;
END_VAR
settings.sPort := SYS_COMPORT1;
settings.ulBaudrate := SYS_BR_4800;
settings.byParity := SYS_NOPARITY;
settings.byStopBits := SYS_ONESTOPBIT;
CASE iState OF
0:
IF NOT bDone THEN
handle := Syscom.SysComOpen2(
pSettings:= ADR(settings),
pSettingsEx:= 0,
pResult:= ADR(result));
bDone := TRUE;
iState:= 10;
END_IF
10:
udiReturn := Syscom.SysComRead(
hCom:= handle,
pbyBuffer:= ADR(arByte),
ulSize:= SIZEOF(arByte),
ulTimeout:= 0,
END_CASE
11-24-2022 07:28 PM
Thanks kai ❤️
