08-21-2024 08:59 AM
I am using ctrlX works version 1.20.10 and ctrlX PLC engineering version 1.20.7.I am running this on a swedish version of windows 10. The language in PLC engineering however is a strange mix of english and german. The texts and pop ups are quite often in german. I know some german, but sometimes this causes some confusion. Is there a cure which does not include changing windows version?
08-30-2024 11:36 AM
We like to check - could you give us some "samples/screenshots" of that, please?
PS: We know, that i.e. the "Add-on installer..." uses German texts.
09-12-2024 06:41 AM
You can change the language settings within ctrlX PLC Engineering without changing your Windows version. Go to Tools > Options, then navigate to Language Settings and select "your prefered language" from the dropdown menu. Restart the software to apply the changes. I hope this will work.
Let me know how it goes.
Thanks
09-20-2024 11:47 AM
Looks like this does the trick! Tnx a lot!
