CXA_MotionInterfaceUser Visualization build error
aFouraker
When building with version 1.20.5 of the CXA_MotioninterfaceUser library the build fails due to an extra comma in a visualization. Is it possible to exclude this from the build until it is resolved?
Just working fine at my side. I also cannot an fault in the code marked on your screenshot. could you point out where the problem exactly is?
The fastest way to change things in the CXA_MotionInterfaceUser, as it is an uncompiled/open library, is to simply open it up with ctrlX PLC Engineering as a library project, do the changes and store/install it as a new version.
aFouraker
The problem is here, there are 2 closed parenthesis in the blue box and one in each red. There is an extra. Trying your solution now and will report back.
Ok, I see. Same brackets on my side but still showing no error with or without it :
(NOT arAxisStatus_gb[VisuAxisNo].Data.PLCOpenState.Disabled) AND (NOT arAxisStatus_gb[VisuAxisNo].Data.PLCOpenState.ErrorStop))
