CXA_DataLayer how to read flatbuffer type? Is there an example?
zhenhui
How to read flatbuffer types and parse flatbuffer types to simple type by CXA_DataLayer lib? Is there some example for this topic?
5 REPLIES 5
See an example I made for reading a safe area:
Declaration:
PROGRAM POU
VAR
	bRead: BOOL;
	fbDL_ReadNodeValue: DL_ReadNodeValue;
	DataRead: CXA_Datalayer.DL_NodeValue;
	strNodePath : STRING;
	bExecute: BOOL;
	bDone: BOOL;
	bActive: BOOL;
	bError: BOOL;
	ErrorID: CXA_Datalayer.ERROR_CODE;
	ErrorIdent: CXA_Datalayer.ERROR_STRUCT;
	strName : STRING := 'Zone_1';
	fbAreas_Read: CXA_MotionCore_fbs.motion_core_fbtypes_SysCfgSafeArea;
	Read_CoordSys: STRING;
	Read_Name: STRING;
	Read_Type: CXA_MotionCore_fbs.motion_core_fbtypes_SafeAreaType;
	Read_Boxes_length: UDINT;
	Read_Boxes: POINTER TO CXA_MotionCore_fbs.motion_core_fbtypes_SysCfgSafeAreaBox;
	Read_Boxes_Int: CXA_MotionCore_fbs.motion_core_fbtypes_SysCfgSafeAreaBox;
	arRead_Active: ARRAY [0..2] OF BOOL;
	arRead_Max:ARRAY [0..2] OF LREAL;
	arRead_Min: ARRAY [0..2] OF LREAL;
	arRead_Unit: ARRAY [0..2] OF STRING;
	i: INT;
END_VAR
Implementation:
IF bRead THEN
	bRead := FALSE;
	strNodePath := CONCAT('motion/cfg/safe-areas/',strName);
	bExecute := TRUE;
END_IF
IF fbDL_ReadNodeValue.Done THEN
	fbAreas_Read.getRootAsSysCfgSafeArea(data:= DataRead.GetData(), size:= DataRead.GetSize());
	Read_CoordSys := fbAreas_Read.getCoordSystem();
	Read_Name := fbAreas_Read.getName();
	Read_Type := fbAreas_Read.getType();
	Read_Boxes_length := fbAreas_Read.getBoxLength();
	FOR i := 0 TO TO_INT(Read_Boxes_length)-1 BY 1 DO
        	Read_Boxes := fbAreas_Read.getBox(i);
		Read_Boxes_Int := Read_Boxes^;
		arRead_Active[i] := Read_Boxes_Int.getActive();
		arRead_Max[i] := Read_Boxes_Int.getMax();
		arRead_Min[i] := Read_Boxes_Int.getMin();
		arRead_Unit[i] := Read_Boxes_Int.getUnit();
	END_FOR
	bExecute := FALSE;
END_IF
fbDL_ReadNodeValue(
	Execute:= bExecute,
	Done=> bDone,
	Active=> bActive,
	Error=> bError,
	ErrorID=> ErrorID,
	ErrorIdent=> ErrorIdent,
	ClientId:= ,
	NodeName:= strNodePath,
	NodeValue:= DataRead);
Thanks a lot for your sample. It's pretty helpful.
I'm reading fbs script_manager_fbtypes_DiagInfo which inculdes string type and array of string type, there are sitll some problems for me:
1. When trying to parse array of string, I can get a valid value of pointer to string by getLasetErrTrace method, but when convert it to string type,  I always get invalid result.
2. Besides, I can always get a value(not zero) by method strPtr := fbsDiag_Read.getLastErrTrace(idx), even though idx is bigger than count.
count := fbsDiag_Read.getLastErrTraceLength();
FOR idx := 0 TO count - 1 DO
   strPtr := fbsDiag_Read.getLastErrTrace(idx);
   IF strPtr <>0 THEN
      Stu.StrCpyA(pBuffer:=ADR(testStr), iBufferSize := SIZEOF(testStr), pStr := strPtr);
   END_IF
END_FOR
3. When trying to read a string longer than 80 length, it's limited to 80(default string length in codesys). For some case, it's not enough to get a string with wrong length.
ErrorStr := fbsDiag_Read.getLastErrText();
I do not get all of your points. Please see my version that works as I expected:
Declaration:
PROGRAM script_manager_fbtypes_DiagInfo
VAR
 	strMyInstancename : STRING := 'MyInstance';
	bRead: BOOL;
	bExecute: BOOL;
	strNodePath: STRING(255);
	bDone: BOOL;
	bActive: BOOL;
	bError: BOOL;
	fbDiagInfo: cxa_automationcore_fbs.script_manager_fbtypes_DiagInfo;
	udiLastMainDiag: UDINT;
	udiLastDetailDiag: UDINT;
	strLastErrText: STRING(255);
	udiLastErrTraceLength: UDINT;
	i: INT;
	arstrLastErrTrace: ARRAY [0..99] OF STRING;
	pLastErrTrace: POINTER TO STRING;
END_VAR
Implementation:
IF bRead THEN
	bRead := FALSE;
	strNodePath := CONCAT('script/instances/',strMyInstancename);
	strNodePath := CONCAT(strNodePath,'/diag');
	bExecute := TRUE;
END_IF
	fbDiagInfo.getRootAsDiagInfo(data:= DataRead.GetData(), size:= DataRead.GetSize());
	udiLastMainDiag := fbDiagInfo.getLastMainDiag();
	udiLastDetailDiag := fbDiagInfo.getLastDetailDiag();
	strLastErrText := fbDiagInfo.getLastErrText();
	udiLastErrTraceLength := fbDiagInfo.getLastErrTraceLength();
	FOR i := 0 TO TO_INT(udiLastErrTraceLength)-1 BY 1 DO
		pLastErrTrace := fbDiagInfo.getLastErrTrace(i);
		arstrLastErrTrace[i] := pLastErrTrace^;
	END_FOR
	bExecute := FALSE;
END_IF
fbDL_ReadNodeValue(
	Execute:= bExecute,
	Done=> bDone,
	Active=> bActive,
	Error=> bError,
	ErrorID=> ErrorID,
	ClientId:= ,
Picture:
hello,
about how to read array of string type in the datalayer, I follow your example to read the data as below.
I am planed to read the offset-xyz value and offset-xyz-units.it is works to read array of LREAL type, but the array of string is always empty, although the  length is corrent.
see my program code:
Declaration:
FUNCTION_BLOCK ReadSets
VAR_INPUT
	strName : STRING;
END_VAR
VAR_OUTPUT
END_VAR
VAR
    bRead : BOOL;
	fbSysCfgPcsSet_Read: motion_core_fbtypes_SysCfgPcsSet;
	OffsetXYZ_length : UDINT;
	Orientation_Length : UDINT;
	OffsetAux_Length : UDINT;
	OffsetXYZUnits_Length : UDINT;
    pOffsetXYZ : POINTER TO  LREAL;
    pOrientation : POINTER TO  LREAL;
    pOffsetAux : POINTER TO  LREAL;
	pOffsetXYZUnits : 	POINTER TO STRING;
	arOffsetXYZ: ARRAY [0..2] OF  LREAL;
	arOrientation: ARRAY [0..2] OF  LREAL;
	arOffsetAux: ARRAY [0..9] OF  LREAL;
	arOffsetXYZUnits: ARRAY [0..2] OF  STRING;
	i: UDINT;
END_VAR
Implementation:
	fbSysCfgPcsSet_Read.getRootAsSysCfgPcsSet(data:= DataRead.GetData(), size:= DataRead.GetSize());
	OffsetXYZ_length := fbSysCfgPcsSet_Read.getOffsetXYZLength();
    Orientation_Length := fbSysCfgPcsSet_Read.getOrientationLength();
    OffsetAux_Length := fbSysCfgPcsSet_Read.getOffsetAuxLength();
	OffsetXYZUnits_Length := fbSysCfgPcsSet_Read.getOffsetXYZUnitsLength();
	//OffsetXYZ
	FOR i := 0 TO TO_INT(OffsetXYZ_length)-1 BY 1 DO
        pOffsetXYZ := fbSysCfgPcsSet_Read.getOffsetXYZ(i);
		arOffsetXYZ[i] := pOffsetXYZ^;
	END_FOR
	//Offset Orientation
	FOR i := 0 TO TO_INT(Orientation_Length)-1 BY 1 DO
        pOrientation := fbSysCfgPcsSet_Read.getOrientation(i);
		arOrientation[i] := pOrientation^;
	END_FOR
	//OffsetAux
	FOR i := 0 TO TO_INT(OffsetAux_Length)-1 BY 1 DO
        pOffsetAux := fbSysCfgPcsSet_Read.getOffsetAux(i);
		arOffsetAux[i] := pOffsetAux^;
	END_FOR
	//OffsetXYZUnits  example faild
	FOR i := 0 TO OffsetXYZUnits_Length-1 BY 1 DO
        pOffsetXYZUnits := fbSysCfgPcsSet_Read.getOffsetXYZUnits(i);
		arOffsetXYZUnits[i] := pOffsetXYZUnits^;
	END_FOR
	bRead := FALSE;
END_IF
//motion/cfg/coord-systems/pcs/sets
strNodePath := CONCAT('motion/cfg/coord-systems/pcs/sets/',strName);
fbDL_ReadNodeValue(
	Execute:= bRead,
@leo1 your example is working fine at my side with a small change. In line 24 in my code I also added the unit conversion and declared "i" as integer:
ctrlX PLC Engineering read PCS setctrlX PLC Engineering read PCS set
