About error in generate code
Chirag03
Hello ,
I am using CXA_LICENSING library . I have code by using function from CXA_LICENSING library . Please see attached picture of code . I have problem by using funciton from library . How can i resolve it ?
Thanks in advance
6 REPLIES 6
So what does the error tell you? Could you please open the messages that is hidden in your screenshot below to get some information?
Thank you for your email.
There are four errors but there is no error description.   please see attahced picture.
Please check the drop down menu beside the error/warning/messages there you can choose from which source the viewer gets its data from.
Thank you very much for your reply . I did as per your last answer ,still no description . Here i attached XML file  for your reference.
Chirag03
Here is correct XML file.
I cannot import your second XML (please try only exporting the POU or application) but when using the first one I will get compile errors as following. You must be able to see similar ones:
ctrlX PLC Engineering - compile errorsctrlX PLC Engineering - compile errors
After inserting the library CXAC_Licensing to the library manager these are gone. Did you add this library in your project?
ctrlX PLC Engineering - Library manager - CXAC_LicensingctrlX PLC Engineering - Library manager - CXAC_Licensing
