12-13-2023 09:44 AM
Hello ,
I am using CXA_LICENSING library . I have code by using function from CXA_LICENSING library . Please see attached picture of code . I have problem by using funciton from library . How can i resolve it ?
Thanks in advance
12-13-2023 10:58 AM
So what does the error tell you? Could you please open the messages that is hidden in your screenshot below to get some information?
12-13-2023 12:26 PM
12-14-2023 09:42 AM
Please check the drop down menu beside the error/warning/messages there you can choose from which source the viewer gets its data from.
12-14-2023 10:58 AM
12-14-2023 12:24 PM
12-20-2023 01:17 PM - edited 12-20-2023 01:18 PM
I cannot import your second XML (please try only exporting the POU or application) but when using the first one I will get compile errors as following. You must be able to see similar ones:
After inserting the library CXAC_Licensing to the library manager these are gone. Did you add this library in your project?
