02-21-2023
02:29 PM
- last edited on
03-16-2023
02:00 PM
by
ThorstenX
I have described all kinematics and axes and than after downloading 3d viewer app. I wanted to visualise my axis with demomodel but after I hit the connect button. demo model does not sync with motion kinematics.
@ThorstenX : Remove broken image link
02-21-2023 03:02 PM - edited 02-21-2023 03:03 PM
From your picture I guess you are using version 1.18 of the system and the ctrlX CORE - 3D-viewer app. Which setting did you insert to connect your motion axes to the animation?
ctrlX CORE web UI 3D viewer axes settings
02-21-2023 04:41 PM
thanks for solution. and there was a problem with axis format I changed to modulo and It should be absolute.
