10-19-2023 03:15 PM
Hello.
We try to set up a Nidec Digitax M753 via Ethercat (CoE) with our Core X3. (SM01.20.5)
We managed to set up axis profile and axis. If we move the drive via Inverter, the current position changes on our Web interface (Core).
So communication it self is working.
As soon as we set the power on (either via MC_Power or via Web interface) we get the following error.
We tried several things described in other topics regarding that issue but nithing solved it.
Does anyone has an idea what to do next?
Thanks a lot
Here are the versions of the used app and other information
Thanks a lot
10-19-2023 04:12 PM
So I guess you already have seen e.g. this topic? We think that the drive needs to long to witch power on after it got the command from our control. This happened at some of the other 3rd party drives also.
To get some more insights please switch on traces of the axisprofile (data layer path trace/rexroth-automationcore/units/comm/axisprofile) and create a system report after error occurred. See how to mentioned here.
10-23-2023 04:07 PM
11-03-2023 11:35 AM
As assumed we can see in the system report that our ctrlX MOTION shows an error that drive needs to long to react on the power on command. So it seems that probably the 3rd party drive is not following CiA 402 conventions completely or in an other way then expected.
02-16-2024 10:45 AM
Did you test with an early adopter version 2.4?
Is this still an issue or can this topic be closed?
