ML_GroupWait
ML_GroupWait
aFouraker
In the older firmware the ulitilty for waiting was available with the ML_GroupWait command. It could be buffered and provided a way to "pause" a series of buffered robot commands. What is the prescribed way to do the equivalent on the ctrlX?
Can you tell us what you want to achieve exactly?
If you want to interrupt the movement at a certain point and continue later on you can use the function ML_KinInterrupt and ML_KinContinue out of the CXA_MOTION library.
If you want to wait for other commands or an external signal to synchronize some motion commands on a very exact scale you will have to use the SoMO (synchronized motion) functions:
