Is it possible to use a Robot 3D circular interpolation function in 2D Cartesian XZ robot ?
giustola69
Is it possible to use the 3D circular interpolation function to make a 2D circular interpolation for example for a XZ cartesian robot or I must use the 2D circular interpolation functions?
Here you have my code: if I run it for the 3 axis intepolatin plane XYZ is working good but I get an error when I run it for the 2 axis interpolation XZ
// Circular Interpolationplane XYZ
IF I_KinPlane = enXYZ THEN
      stML_KinMoveCircleData3D.In.KinName                      :=            I_strKinName;
      stML_KinMoveCircleData3D.In.CmdCircleData.CmdKinCircleData[0].Meaning := IP_X;
      stML_KinMoveCircleData3D.In.CmdCircleData.CmdKinCircleData[0].Value := I_IntermediatePosition[0];
      stML_KinMoveCircleData3D.In.CmdCircleData.CmdKinCircleData[0].Attribute:=ABS_VALUE;
      stML_KinMoveCircleData3D.In.CmdCircleData.CmdKinCircleData[1].Meaning := IP_Y;
      stML_KinMoveCircleData3D.In.CmdCircleData.CmdKinCircleData[1].Value := I_IntermediatePosition[1];
      stML_KinMoveCircleData3D.In.CmdCircleData.CmdKinCircleData[1].Attribute:=ABS_VALUE;
      stML_KinMoveCircleData3D.In.CmdCircleData.CmdKinCircleData[2].Meaning := IP_Z;
      stML_KinMoveCircleData3D.In.CmdCircleData.CmdKinCircleData[2].Value := I_IntermediatePosition[2];
      stML_KinMoveCircleData3D.In.CmdCircleData.CmdKinCircleData[2].Attribute:=ABS_VALUE;
      stML_KinMoveCircleData3D.In.CmdCircleData.CmdKinCircleDataSize:=3;
      stML_KinMoveCircleData3D.In.CmdKinPose.CmdKinTarget[0].Meaning:= X;
      stML_KinMoveCircleData3D.In.CmdKinPose.CmdKinTarget[0].Value:=I_EndPosition[0];
      stML_KinMoveCircleData3D.In.CmdKinPose.CmdKinTarget[0].Attribute:=ABS_VALUE;
      stML_KinMoveCircleData3D.In.CmdKinPose.CmdKinTarget[1].Meaning:= Y;
      stML_KinMoveCircleData3D.In.CmdKinPose.CmdKinTarget[1].Value:=I_EndPosition[1];
      stML_KinMoveCircleData3D.In.CmdKinPose.CmdKinTarget[1].Attribute:=ABS_VALUE;
      stML_KinMoveCircleData3D.In.CmdKinPose.CmdKinTarget[2].Meaning:= Z;
      stML_KinMoveCircleData3D.In.CmdKinPose.CmdKinTarget[2].Value:=I_EndPosition[2];
      stML_KinMoveCircleData3D.In.CmdKinPose.CmdKinTarget[2].Attribute:=ABS_VALUE;
      stML_KinMoveCircleData3D.In.CmdKinPose.CmdKinTargetSize:=3;
      stML_KinMoveCircleData3D.In.Source             :=         'Kin MoveCirc3DAbs function ';
       ML_KinMoveCircle3D(Data:= stML_KinMoveCircleData3D);
END_IF
IF I_KinPlane = enXY THEN
                                    stML_KinMoveCircleData3D.In.CmdCircleData.CmdKinCircleDataSize:=2;
                                   stML_KinMoveCircleData3D.In.CmdKinPose.CmdKinTargetSize:=2;
END_IF
// Circular Interpolationplane XZ
IF I_KinPlane = enXZ THEN
                                    stML_KinMoveCircleData3D.In.CmdCircleData.CmdKinCircleData[1].Meaning := IP_Z;
                                    stML_KinMoveCircleData3D.In.CmdKinPose.CmdKinTarget[1].Meaning:= Z;
END_IF
// Circular Interpolationplane YZ
IF I_KinPlane = enYZ THEN
                                    stML_KinMoveCircleData3D.In.CmdCircleData.CmdKinCircleData[0].Meaning := IP_Y;
                                    stML_KinMoveCircleData3D.In.CmdKinPose.CmdKinTarget[0].Meaning:= Y;
END_IF
I did some tests with following results:
Working:
  • XYZ cartesian with 3D circle
  • XYZ cartesian with 2D circle
  • XY cartesian with 2D circle
Not working:
  • XY cartesian with 3D circle
I added my test program here so you can open it.
In short: For commanding an 2D kinematic an 2D circle commands needs to be used.
In long: A 3D circle is not possible to use with a 2D kinematic, as the calculations are done 3-dimensional and so 3 coordinates are expected, but the transformation is not supporting 3 dimensions so only 2 coordinates are useable.
