01-04-2024 10:29 AM - edited 01-04-2024 10:37 AM
While doing some test on the CtrlX Flexprofile I found a strange behaviour after a cam profile switch.
Configuration:
Real Axis Linear Module = 1000
FB Settings:
Flexprofile 0 =>
Can you help me to understand why we have this behaviour ?
01-04-2024 02:57 PM
I found the reason for the strange behavior I had encountered and it was due to an incorrect setting of the coupling mode of the new profile which was set to SLAVE_ORIGIN_MASTER_ORIGIN and which therefore did not allow the axis to synchronize with the second profile because it was trying to bring the slave axis back in origin and therefore to zero. By setting the ProfileEntry as shown in the figure below, the profile change works correctly.
Many Thanks to Kohl Juergen (DC-AE/STS1) <Juergen.Kohl2@boschrexroth.de>
Giuseppe
