07-22-2024 03:05 PM
I am trying to command a ctrlX Drive throught CoE and with FSoE with a ctrlX Core X7 V2.6 and I have also plugged a SAFEXC15 as a FSoE Master,
I have configured the drive in modulo but the problem is that if try to switch to "Running" the system does not allow me and two errors appears,
I do not know how to create this "axisprofile" task and I have configured the axis in this way,
What should I do?
Thank you,
07-22-2024 05:33 PM - edited 07-22-2024 05:34 PM
Which firmware version are you using in the ctrlX DRIVE?
07-23-2024 08:56 AM
Hello, FW 0504
07-23-2024 01:20 PM
Hello, can you provide a systemreport of your control with the active app data included.
In case of a SAFEX in your project it could be a problem with the configuration. In this case you can see it on ethercat. If one devices doesn't go to OP there could be a problem with the FSoE connections.
07-23-2024 01:25 PM
so can you check this parameter and set it to -1
07-25-2024 08:45 AM
2 weeks ago
Are there any news? is this still a problem?
