04-24-2023 11:37 AM
the PR41 we have has a DisplayPort output. The screen we are using has only HDMI input.
Anybody as an idea how to get this to work?
We have tried with different cables and converters, but without succes.
04-24-2023 11:55 AM
Forgot to mention that we are using this display
04-24-2023 02:05 PM
Hello Servodude,
Have you tested our DP to HDMI active converter?
Accessory for Control
1 VAC07.1SAA-DPN-HDM-01,0
R911399838
Adapter cable active DisplayPort to HDMI
For connection of splitter VAC08.1 to IPCs of series PR/VR
Input: DisplayPort connector.
Output: HDMI connector.
Cable length: 1 m.
Hope it helps,
Luis
