Hello Community,
Are there any examples and possible to save data through node red to ctrlx SD card and thumbdrive?
Warmest regards,
See this thread for how to write files in Node-RED. The path to the SD card is "/media/mmcblk1p1/" like mentioned e.g. in this thread.
At the moment we are encountering problems when writing files from Node-RED to the SD card and are investigating it.
Seems ok saving on Thumbdrive with NR
Regards.
"id": "c70adb607e8ee8d9",
"type": "group",
"z": "4294d07e6727c12e",
"name": "Write / read Data on USB card",
"style": {
"label": true
"nodes": [
"30af8cfec70a014b",
"64eb31bac970858b",
"714035c6e3fad194",
"793d94daaf7fe5b2"
"x": 174,
"y": 1499,
"w": 632,
"h": 122
"id": "30af8cfec70a014b",
"type": "file",
"g": "c70adb607e8ee8d9",
"name": "",
"filename": "/media/sda1/myfile.txt",
"appendNewline": true,
"createDir": true,
"overwriteFile": "false",
"encoding": "none",
"x": 500,
"y": 1540,
"wires": [
"714035c6e3fad194"
"id": "64eb31bac970858b",
"type": "inject",
"name": "",
"props": [
"p": "payload"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "",
"payload": "",
"payloadType": "date",
"x": 280,
"y": 1540,
"wires": [
"30af8cfec70a014b"
"id": "714035c6e3fad194",
"type": "file in",
"name": "",
"format": "utf8",
"chunk": false,
"sendError": false,
"encoding": "none",
"allProps": false,
"x": 500,
"y": 1580,
"wires": [
"793d94daaf7fe5b2"
"id": "793d94daaf7fe5b2",
"type": "debug",
"name": "",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "true",
"targetType": "full",
"statusVal": "",
"statusType": "auto",
"x": 710,
"y": 1580,
"wires": []
