05-15-2024 12:55 PM
I have a problem with using InfluxDB with an external micro SD card.
here, I've followed this description already IIoT: Use ctrlX CORE as a monitoring platform using InfluxDB and Grafana (boschrexroth.com)
and tried to unmount and re-mount the card again.
Yet, I still receive an error message which hinders me from using InfluxDB:
What is wrong? Do you have an idea?
05-15-2024 09:42 PM
Hi @ctrlXW-ChrisB ,
Could you please post your influxDB configuration file?
Also, what versions of InfluxDB and ctrlX OS are you using?
If you could also provide a system report, or other information from the diagnostic logs, that would be useful.
05-16-2024 11:58 AM
first thing I would try is:
05-16-2024 01:23 PM
Thanks to both of you!!
While preparing influxDB config file and system report, I received Nick's proposal and tried it.
And.. problem solved! Deletion of App and re-install helped that I could eliminate the error!
Thanks to you!
Christian
