06-28-2022 05:31 PM
I'm trying to connect a CtrlX Core to another CtrlX Core with the SmartFunctionKit Handling application. SFK4H has an OPC UA server and I want to send Commands from another CtrlX Core with Node Red.
With the OPC UA Contrib palette and the OPC UA client node I have a certificate failure (Picture attached).
This same connection to a XM without security works perfectly.
I understand that I have to install some certificates in the CtrlX Core client, in the Certificates & Keys/Node Red?
I have to specify the path in the Node Red node (Picture 2)?.
A short guide to what certificates I need and where to store them could be provided.
Thanks in advance.
06-29-2022 11:04 AM
!!!Using self-signed certificates is only recommended for test, not for production!!!
If you're client certificate is not selfs-signed, you have to
Ensure openssl to be installed on the system and the path added to your environment path variable.
Ensure Node.js to be installed on the system. We recommend to use the latest LTS version.
Install node-opcua-pki
:: GENERATES A CA CERTIFICATE AND A DERIVED OR SELF-SIGNED CERTIFICATE FOR OPC UA USAGE (*.PEM FORMAT, INCLUDING PRIVATE KEYS) USING NODE-OPCUA-PKI AND OPENSSL
@echo off
::https://github.com/node-opcua/node-opcua-pki
::setup
::Create self-signed certificate enabled: 0/1
set CREATE_SELFSIGNED_ENABLED=1
set CRYPTO_SCRIPT_PATH=.\node_modules\node-opcua-pki\bin
set CRYPTO_SCRIPT=node %CRYPTO_SCRIPT_PATH%\crypto_create_CA.js
set CA_DIR=%CD%\CA
set PKI_DIR=%CD%\PKI
set CERT_DIR=%CD%\certs
set KEYSIZE=2048
set VALIDITY_DAYS=3650
::CA
set CA_SUBJECT_NAME=xxxMyNamexxx
set CA_SUBJECT=/C=DE/ST=xxxMyStatexxx/L=xxxMyTownxxx/O=xxxMyOrganisationxxx/CN=%CA_SUBJECT_NAME%/emailAddress=xxxMy@Mailadress.xxx
set CA_CERT_PATH=%CA_DIR%\public\cacert.pem
set KEY_PATH=%PKI_DIR%\own\private\private_key.pem
::client
set CLIENT_SUBJECT_NAME=NodeOPCUA-Client@xxxMyHostNamexxx
set CLIENT_KEY_PWD=xxxMyKeyPasswordxxx
set CLIENT_SUBJECT=/C=DE/ST=xxxMyStatexxx/L=xxxMyTownxxx/O=xxxMyOrganisationxxx/CN=%CLIENT_SUBJECT_NAME%/emailAddress=xxxMy@Mailadress.xxx
set CLIENT_APPLICATION_URI=urn:xxxMyHostNamexxx:NodeOPCUA-Client
set CLIENT_CERT_NAME=%CLIENT_SUBJECT_NAME%.pem
echo GENERATES A CA CERTIFICATE AND A DERIVED OR SELF-SIGNED CERTIFICATE FOR OPC UA USAGE (*.PEM FORMAT, INCLUDING PRIVATE KEYS) USING NODE-OPCUA-PKI AND OPENSSL
echo Please edit this script to setup, first!
::proceed?
:again
set /p answer=Proceed (Y/n)?
if /i "%answer:~,1%" EQU "Y" goto proceed
if /i "%answer:~,1%" EQU "n" goto end
goto again1
:proceed
::echo initializing ...
::rmdir %PKI_DIR% /Q /S
::mkdir %PKI_DIR%
::rmdir %CA_DIR% /Q /S
::mkdir %CA_DIR%
echo create certificate ...
if %CREATE_SELFSIGNED_ENABLED%==1 (
%CRYPTO_SCRIPT% certificate --root=%CERT_DIR% --selfSigned --CAFolder="%CA_DIR%" --PKIFolder="%PKI_DIR%" --subject="%CLIENT_SUBJECT%" --validity=%VALIDITY_DAYS% --output="%CLIENT_CERT_NAME%" --applicationUri=%CLIENT_APPLICATION_URI%
) else (
%CRYPTO_SCRIPT% certificate --root=%CERT_DIR% --CAFolder="%CA_DIR%" --PKIFolder="%PKI_DIR%" --subject="%CLIENT_SUBJECT%" --validity=%VALIDITY_DAYS% --output="%CLIENT_CERT_NAME%" --applicationUri=%CLIENT_APPLICATION_URI%
if %ERRORLEVEL% NEQ 0 (
goto error
echo convert certificate to *.der format ...
%CRYPTO_SCRIPT% toder "%CLIENT_CERT_NAME%"
goto error
echo dump ...
%CRYPTO_SCRIPT% dump "%CLIENT_CERT_NAME%"
goto error
echo.
echo fingerprint
%CRYPTO_SCRIPT% fingerprint "%CLIENT_CERT_NAME%"
goto error
echo.
echo CA certificate
echo %CA_CERT_PATH%
echo.
echo private key
echo %KEY_PATH%
echo.
:end
:: ERROR HANDLING
::echo %ERRORLEVEL%
:success
:: Success
color A0
pause
exit 0
:error
:: Error
color C0
pause
exit /B %ERRORLEVEL%
06-29-2022 11:23 AM
Hi David08,
the settings in the screenshots work for me, you can select eg. "AES128_Sha256_RsaOaep" and "self-signed certificate".
Also other settings should work, plaease see other screenshot.
You need to trust the certificate in the ctrlX CORE where the server is running. Settings --> Certificates&Keys --> OPC UA Server
If you want to use your own certificates on client side you can store them via the web interface in Settings --> Certificates&Keys --> Node-RED .
Access from Node-RED is with this path possible:
/var/snap/ctrlx-node-red/common/package-certificates/ctrlx-node-red/node-RED/own/certs/YOURcert.crt
/var/snap/ctrlx-node-red/common/package-certificates/ctrlx-node-red/node-RED/own/private/YOURKey.pem
/var/snap/ctrlx-node-red/common/package-certificates/ctrlx-node-red/node-RED/ca/YOURCAcert.crt
Alternatively you could use the ctrlX AUTOMATION Nodes to access the remote datalayer.
06-29-2022 04:49 PM
Thanks CodeShepherd and TheCodeCaptain,
I have used the solution with Node Red CtrlX Automation Nodes. They work just like the OPC UA. I've done some tests with the certificate but it's a bit complicated for me and it didn't work for me. As I'm testing for a Demo I'm going to use the CtrlX Nodes.
Thank you very much for the quick reply to both of you
