08-06-2024 02:52 AM
Hi Community,
I am using the ctrlX IO XI522001 Modbus RS485, the device is having error in the RTU_Master function block. Is there an ErrorID description to refer to?
Warmest regards,
08-06-2024 10:00 AM
Hi @Open
check the library, there are possible error codes directly in the function block description.
You can also find examples for structured text.
a month ago
