03-01-2021 08:49 AM
I have a problem with ctrlXI/O.
I am working with a ctrlXcore standalone.
I get an exception always when trying to save.
It looks stanrge to me because I can download the config inside the ctrlXcore
03-01-2021 09:01 AM
Please tell us the version of your installed ctrlX Ethercat app and ctrlX WORKS on your engineering PC.
03-01-2021 09:53 AM
03-01-2021 11:35 AM
Sorry for asking for infos again but please add also a system Report from your ctrlX WORKS.
03-01-2021 12:06 PM
03-01-2021 01:57 PM
Hey there. You added the report of your ctrlX CORE so the controller itself.
The one I mentioned in the post before is the same but of the ctrlX WORKS. So the Engineering tool.
03-01-2021 02:07 PM
03-02-2021 02:43 PM - edited 03-02-2021 02:43 PM
It seems that the internal communication from engineering to PLC backend is stucked. Could you please do a repair installation or reinstall ctrlX WORKS?
03-02-2021 03:41 PM
I did a repair
that's exactly the same issue.
Problem not solved. I hope that the March Release will solve it.
03-02-2021 03:58 PM - edited 03-02-2021 04:01 PM
Could you please send again the actual system report of the ctrlX WORKS? Thanks a lot.
How do you open the IO engineering? Via the Web interface of the control or via the ctrlX WORKS?
Please try to switch off the project synchronization, save and switch it back on.
Please send me a private message if you need direct support.
03-02-2021 06:35 PM
03-02-2021 06:38 PM
when I open from ctrlXWorks it works as excpected
03-04-2021 11:47 AM - edited 03-04-2021 11:49 AM
After checking your last information it seems, that you opened the WebInterface of the ctrlX CORE via the IPv6. At the moment this ip is directly copied to the target setting in the engineering and these tools cannot use it. So actually you have to insert the IPv4 by hand in this constellation. If the error will stay, please open your WebInterface of the ctrlX CORE via the IPv4 and open the engineering from there.
Could you check this two possibilities please and tell if it working at your side?
There will be some improvements in the next release RM21.03 (version 1.8.x).
