09-25-2023 05:05 PM
Is there a guide on how to functionaly use station alias 0x0012 for XB-EC-12 with FW v1.4.0? Simply activating identification and downloading the configuration is not the proper method, from my testing, because the device shows as not connected.
10-18-2023 01:00 PM
With which tool you tried to set? When tool and controller support it, you can change it.
current supporting tools are TwinCAT or Omron software, new value need to be written and than the device need a power cylce to apply the new address
11-13-2023 03:48 PM
Moved to own topic from "Use CtrlX IO Engineering to change EtherCAT Address question?".
@EngJay Is this still an issue or can this topic be closed?
11-13-2023 05:34 PM
Yes, we can close the topic, thanks. Unless you want to give a hint, when the same functionality will come to ctrlX IO Engineering software.
