Invalid requested state change for XI432204 after failed firmware upgrade
JG89
Looks like that a failed firmware upgrade resulted in error of state for analog output card XI432204.
Error messages in sequence:
Looks like for the first try the wrong file was selected, and for the second try error occured while transferring the efw file. After this I could set the card to Init state, but no other state change is possible anymore.
What could be the solution to this issue?
cc2go
Hello, do you tried to do a power cycle? Normally the module shall load fallback image to avoid a corruption. Please check connection is proper, because WKC seems some connection issue.
Please power cycle module and retry.
My problem was that I am remotely connected, so no power cycle was possible, but I could grab someone half an hour ago who did it, and indeed it solved this issue. I could perform now the firmware update and my original issue (wirebreak on channel 3) is also gone!
THank you so much for the fast reply though!
