10-30-2023 10:49 PM
I am developping a slave communication electronic board based on ETHERCAT.
Master will be Ctrlx CORE.
I am using LAN9252 from Microchip. I found the following XML file:
https://ww1.microchip.com/downloads/en/DeviceDoc/Microchip%20EVB-LAN9252-4PORT.xml
How is it possible to download it throught CTRLX IO to the chip once communication is established.
I have been able to do it using TWINCAT 3. Not cleat how to do it in REXROTH environnement.
Thanks / Danke
10-31-2023 09:08 AM
ESI XML device description files you can install via Tools and Device Repository or during Scanning the Bus within ctrlX IO Engineering, than it shall work.
ctrlX IO Engineering you need to create the EtherCAT Master config for the ctrlX CORE
