03-15-2024 05:18 PM
In VPB40.4, there was two display port, CDI & DP.
And it was possible to connect monitor directly on Display port and another ctrlX HMI DE ( R911404268) on CDI+ port.
And so external monitor was only used for monitoring and HMI was used for machine operations.
How can we do similar configuration with ctrlX CORE or ctrlX IPC??
03-25-2024 09:21 AM
we launch soon the successor product of VPB40.4. Its called PR5. Here you have also the possibility of 2x DP and 1xCDI+.
Does this answer your questition? What is your usecase in specific?
03-25-2024 09:24 AM
Hello
Thanks. similar option possible with X3 or X7 ?
Will PR5 be available with ctrlX OS ?
03-25-2024 10:41 AM - edited 03-25-2024 10:49 AM
PR5 with ctrlX OS is technical possible BUT w/o realtime. So far it is not a product to sell yet. Please contact me regarding this topic in a private message.
Regarding X3 and X7 --> here you do not have CDI+, but 1x DP is possible.
03-25-2024 10:51 AM
Moved to corresponding forum ctrlX HMI.
