13 hours ago
I have a webIq application where the used memory in ctrlX slowly grows until the core will go into error. Takes maybe 3 days or something until the error occurs. When looking in the core there are 26 processes active from webIq, and all are growing at the exact same rate. Maybe they are refering to the same memory area, I dont know. Until the error occurs, the webIq app and the core is working fine. Nothing strange at all.
7 hours ago - last edited 7 hours ago
Hi @JohanRos ,
My first guess is that the application is generating a ton of logs and you've disabled the log file size limit. Can you check the size of the log file in the runtime manager?
Do you have any custom code used in the application that might be writing to the WebIQ server database?
There have been a few patches since your installed version as well. You can find the latest in the collaboration rooms.
