07-05-2023 05:13 AM - last edited on 07-17-2023 03:23 PM by CodeShepherd
After connecting the panel to the USB-C, any setup needed? Or it should automatic update? Because after i connected the display with usb c seems nothing happened
07-05-2023 09:53 AM - last edited on 07-17-2023 03:24 PM by CodeShepherd
EDIT: Moved to own topic from this one.
After connection of panel to PC over USB cable, the panel should display
- USB mass storage:
- Press "Enter" key and it should show: Panel Firmware
- Press "Enter" key again and you should get to the menu showing the actual firmware on the panel:
- Provided you loaded a new firmware of the panel to the correct folder on the panel (using the USB connection) by pressing the "Enter" key the new firmware of the panel would be updated
If it gets stucked in this process and doesn´t react on any entry over the "ESC" or "Enter" key you have to return the panel for exchange to Bosch Rexroth.
