04-13-2021 02:38 PM
for upcoming servomotors MS2S as single cable connection, wich drive connector port shall be used for ?i.e EC port or the same as Acurolink on board ?
04-14-2021 07:54 AM
The onboard interface is capable to connect and read both AcuroLink and ctrlX SENSE as well. There is no need to add the EC interface option for MS2S. And, there is no ready made cable that connect your MS2S motor with single cable connection to the EC interface.
